BHG Question...
maniakmx3
Cape Carteret, NC
Yeah I know it's another one.
I'm going with the HKS 1.2mm MHG and ARP bolt n stud kit (straight from Titan motorsports) Now this engine is a brand new rebuild, the builder botched the torquing and the OE HG blew within 30miles.
The block is a brand new reman, and the head was just machined. Should I have them resurfaced anyway? The car NEVER overheated. It acted up once, parked it. Checked the oil and the oil had some cream in it and the radiator was pressurized.
I was thinking if I pulled the head off and everything was still spotless it wouldn't be an issue. What do you guys think?
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
If you get a MHG, your head and block have to be within RA spec. I doubt it is in spec with the stock HG you have on right now. Just my 2 cents.
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
Is it going to be a DD or a high hp supra? If your sticking mostly stock or even BPU, I'd use the felpro and arp head studs.
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
If its about 400 hp or lower, stick with OEM Felpro. If not, or if you want extreme piece of mind, pull it and get it in spec, and do a MHG
mattsplat72
is sofa king
Jan 17, 2006
1,738
Personally I just did mine( see build thread) I would get the head check by a good machine shop just for peace of mind shouldn't cost much . After you do that might as well go with a MHG that way if you want to go big later it is one less thing to tackle
maniakmx3
Cape Carteret, NC
Alright, I went ahead and picked up the felpro. I'm mainly just looking to get it up as dd for the time being. Performance is in the future, but right now I need to get to work so I can pay my bills and buy the performance parts.
Another quick question. ARP Bolts or ARP Stud Kit? the stud kit is only like 20 bucks more. Which should I go with?
edit: I'll also mention that 2 of the exhaust side bolts were removed without a wrench, the other 5 exhaust side bolts were removed effortlessly with a ratchet. THe Intake side was still holding it's torque.
quake
toyota tech
Apr 13, 2005
619
r.i.
go with the studs and tighten them in steps they apply a more even torque than bolts also after using a stock style gasket you would have to resurface again before using a metal gasket
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
That is VERY common, Bigaaron at drifmotion sells a DIY helicoil upgrade including larger studs for the exhaust side to prevent this from happening again.
maniakmx3
Cape Carteret, NC
Well we got the head off today and it is SPOTLESS. the exhaust side of the Number 3 Cylinder was blown on the gasket. We're puttin it all back together tomorrow. I'll let you guys know how it turns out.
Dec 3, 2003
6,653
Canada
Although the block and head has been machined you will want to lap the block (at least I would) Be sure to check for any rivets that may be on the new gasket and in the way of the clamping surface. (it happens) Torque to 90-100 (mine is at 100) with ARP studs.
HTH
Duane
