I have a occasional smell of coolant in the car. I assume its from the heater core or a hose to it.
There is no coolant on the floor and the coolant loss is just a several onces for over a month.
I see there is a hose under the hood that has or is seeping as there is red coolant crusted on the hose at the fitting. Could this be what is happing in the car?
BG has a Universal Cooling System Sealer.
BG Universal Cooling System Sealer is composed of refined organic fibers, rust and corrosion inhibitors, a buffering agent and anti-foaming ingredients. It stops head gasket seepage and seals small leaks in the radiator and heater cores. The rust and scale inhibitors help provide better heat transfer properties. It is compatible with all types of coolants and harmless to all metal or rubber parts.
Is this stuff safe to put in the rad? Should I use it or should I just dig into the dash and find the leak?
