Best method of tightening cam cover bolts
SupraMan1987
258
Hickory area, NC
I am going to most likely put my freshly powder coated cam covers back on in the next few days. My question is, what is the best method of tightning down the bolt that go to a crazy low torque setting? I have switched out to stainless bolts to get away from the screws. So, what method do you guys use? I do not have a torque wrench that goes as low as the factory spec. Let me know guys.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
stick to factory spec and get a torque wrench that'll let you do it properly.
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
A nut driver of some sort will prevent you from unwittingly busting the crap out of it, but nothing short of a torque wrench will get the torque spec perfect.
If you use a nut driver (a screw driver for bolts, basically), you can tighten the bolts down equally and incrimentally, and slowly work the cam cover down tight. If some bolts are tighter than others it won't seal, so it's a tedious operation. Most average humans can't get much more than 25 or 30in-lbs of force onto a screw driver with one hand. So you'll be ok if you're not some half-breed gorrilla.
Asterix
Lurker of Power
Vienna, VA
I used socket-head screws. With a long ball-nose hex driver that looks like a standard screwdriver, I can get to all of them but one with the car together. Like Keros suggested, I just can't get them too tight that way - I'm not strong enough. I figure as tight as my hand can get them is good enough.
I'd rather not use hex-head bolts since it's too tempting to use a wrench on them.
Asterix
