best ignition timing
88YotaTurbo
658
Wolcott, Ct.
What is the best ignition timing to run on an 1988 turbo with intake, 3" elbow back exhaust. 93 octane, Autolite plugs?
I have a dyno day coming up and I wanted to run through some pretune options
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I'm not going to bother with a guess, but, for anyone else to give you a recommendation they'll probably want a little more info: what temp. spark plugs, what gap, how many psi of boost, stock HG?
88YotaTurbo
658
Wolcott, Ct.
well i'll start.
spark plug is an autolite 3923 gaped to .28
want to push 14-16 psi of boost at dyno. normal psi is 10-12
i'm going to say yes it is stock HG but the previous owner said he rebuilt the motor but i'm not sure.
88YotaTurbo
658
Wolcott, Ct.
well i've seen people running 12-14* btdc in the past. I know stock is 10*btdc. what is the advantage or any to running retarded timing?
88YotaTurbo
658
Wolcott, Ct.
well i can run up to 14.5 then i hit fuel cut before I moved the afm screw all the way out from the 3/4 in from stock. 16psi mark is probably a dream but we'll see.
