bend dipstick to clear manifold?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
I've had to rotate my dipstick tube 90° counterclockwise to clear the new manifold, but now the dipstick runs through runners 2 and 3, rubbing on 3. Can I bend the dipstick to clear the runners without touching, or will the heat hurt the dipstick handle/seal or other parts? I'm either going to have it recoated with ceramic or wrapped and sealed, but still worry about this part. Any advice?
Thanks!
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
I would definitely wrap that manifold if you're going to run it that way. Or buy a universal dipstick with the longer flexible tube.
Clip
Oct 16, 2005
2,738
9
Virginia
Duane, how custom was your dipstick? I know wesbeech is making one, but didnt know if you were using that one or one of your own.
george, what do you mean by the dipstick tube being ahead of the oil filter? as in not the same routing as mine?
Dec 3, 2003
6,653
Canada
I had a Lokar for a few years. I run it for the oil and trans. :)
Duane
Clip
Oct 16, 2005
2,738
9
Virginia
Duane
what was the model #, if you still remember? and was that an entire tube/stick assembly that pressed into the block?
Dec 3, 2003
6,653
Canada
Correct, it plugged in the block. Dipstick and tube. I don't remember part #, sorry. Wesbeech is selling them now, no? Get one from him. They are awesome as they're flexible, which is what I needed.
Duane
gofastgeorge
944
Texas
Yup.
One of my blocks had the dip stick more forward.
And my turbo block had it back like yours, so I plugged the rear position,
and put the tube forward like the other one.
There is a spot in the casting for it there.
I just made a press in plug to seal off the rear one.
joel903
314
Conover,NC
Please if you guys can post the part number of the lokar dipstick for the 7mgte it would be appreciated. I didn't know this existed, now i know and i want one.
Clip
Oct 16, 2005
2,738
9
Virginia
joel, check with wesbeech. he sells one ready-made for the 7m.
akito, don't know how yours was routed unless it was up front. i've got mine in the rear position, and it's turned 180 degrees right now so it has almost an inch of clearance on either side of runners 3 and 4 (directly below the TB). i'll get pics of it tomorrow.
george, i spose i'll have to drill the forward position out?
