Battery light on.
S.A. supra
2,405
Buda, Texas
I'm having some trouble with my aristo swap. my battery light will not turn off. I have had the alternator check and its good. battery is good, I double checked the wiring, and that checks out good. I just cant figure it out! it did turn off once for a couple of starts, but now its back on. any help would be appreciated.
S.A. supra
2,405
Buda, Texas
Alt pin# 1- L - Yellow to yellow mkiii harness
Alt pin#2- IG- Red/ Blue Stripe to Black/ yellow mkiii harness
Alt pin#3- S- White to White mkiii harness.
satx88supra
388
San Antonio
S.A. supra;1924613 said:
What fuses?
This
And the TSRM says to check the engine fuse (15A) on the drivers inside fuse panel.
f00g00
586
Kuwait
Your pins are off.
Pin 1 on ALT is white (you have them going correct) (your calling pin 1 pin 3)
Pin 2 on ALT is Y-G (yellow with green stripe) should go to your charge light
Pin 3 on ALT is B-Y ( black with yellow stripe) should go to AM1 on engine fuse box. (your calling pin 3 pin 1)
looks like you have 2 and 3 reversed but to be sure read with a meter.
S.A. supra
2,405
Buda, Texas
Son of ahhhh. I think you are right I was so worried about getting the wires correct, which they are. That I had not noticed that the plug was pinned wrong. I did pin that plug myself because the plug had cracked. Ill let you know later. Thanks for the help.
S.A. supra
2,405
Buda, Texas
f00g00;1924799 said:
Your pins are off.
You were right! I pinned the damn plug wrong, all is good now. Time to get some insurance and get this one and a half year project on the road.
Suprapowaz!(2)
2,870
San Antonio, Tx.
:: facepalm ::
J/K, I'm glad someone was able to help with that. I sure wasn't. Let's get it going Mike!!
