Bad TPS?? SAFC throttle % going crazy on me
suprafanatic
1,607
Greenwood, IN
Iv recently run into a problem with my Throttle position sensor or somthing along those lines. While im cruzing on the interestate the throttle position % on the SAFC just goes nuts and makes the car kinda jumpy cause its adding and taking away fuel really fast. The throttle % was bouncing from 0.0% all the way up to 100% even at idle.
so i dont know if its bad wiring with the safc, or if its the actualy TPS.. any ideas? and the problem comes and goes. Seems like it starts doing it if i boost some.
suprafanatic
1,607
Greenwood, IN
well the throttle problem was the TPS, it needed adjusted. The check engine light is still on. I borrowed a friends afm electronics and put them on my car to see if it made a difference. His electronics actualy made my car run worse than what i already had on it. so im not sure whats going on there. His electronics are in good working order to. as for code 14 what should i do??
spoolint78
Representing T.O
T.O
swap ignitors, double check to see if the cps is within spec per tsrm.
Reset ecu, start it and check to see what codes reappear
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
As I said in the PM I just sent you I bet this is all caused by you AFC wiring, it being taped up and then pulling the hardness through the firewall hole I bet knocked it loose.
Next weekend Matt and I will be at his parents house again starting on my car, if you are still issues stop by and we will take a look at this.
