Bad SparkPlugs or Injectors
Status
Not open for further replies.
NiGMa
119
Australia
Hi Guys,
Been trying to maintain this car of mine for a while now. Just want your thoughts on a new problem.
Turn the car on, I get rumbling sound as if one of the cylinders isnt firing, but it goes on and off, obviously car doesn't drive well like this, if I rev it up to about 3000rpm it misses a beat alot less frequently, after about 10mins or when engine reaches operating temperature, the missing goes away, not entirely though, if i let it idle it will miss every so often, but no way near as bad as when i first start the car cold.
I have tried:
-Check spark on all six wires, with a light gun, ALL FINE!!!
-cleaned 5,6 spark plugs, had a heap of oil in the valley!
-wiggled injector wires around
I will try:
-temporarily install known working spark plug into 5,6
I had a similar problem about 10months ago, I changed a spark plug with an old one from my bhg engine, solved it completely.
I think the problem is the same this time. What do you think? which component would be dependent on engine temperature? I guess i can visualize the sparkplug covered in oil and only every now and then sparking, then by the time it heats up the oil is evaporated leaving a clean surface to arc on.
Thanks guys
NiGMa
m0tive
4
San Jose, CA
i had this same problem a couple of months ago.. my problem was #4 and #5 fuel injectors. You should try a fuel system cleaner first because that can simply fix it and if it doesnt you have to change your fuel injectors...
NiGMa
119
Australia
MDCmotorsports said:
Make sure you don't have oil or water in the plug galley.
Yeah I know, I have this problem every few months, its probably my cam covers leaking oil. I should get to that soon. I don't think thats the problem though, unless the oil has soaked the plugs and it cant make a spark. Question: is oil supposed to be able to get into the cylinders through the spark plug hole? or would the reason the plugs are covered in oil be that as I pull them out the oil runs onto it?
I will try an injector cleaner.
I am using NGK Iridium's, they don't seem to last long though the first one died in a about a year, I dont know what caused it. I only drive 15,000kms a year. ???
NiGMa
119
Australia
I FOUND OUT WHAT IT WAS!
Wanna take a guess???
I put normal unleaded fuel in just before the problem started, i've been running on the 98 octane fuel we have here in Australia for years and the other day I put normal in just to see what would happen. But I forgot! Its been gradually getting better since I've refueled with 95 octane. I'll put some injector cleaner in next time too, lol how funny!
Thanks anyway guys! =)
MA70_Powa
Boost Addict
Jun 17, 2007
180
Tasmania
Hey, just thought I'd add to this post cuz I have the same problems with my car. I've changed my oil, oil filter, leads, spark plugs and cleaned the air filter.
I've been running it on 98 octane petrol since I got it and the problem is still there. I even put 2 bottles of injector cleaner though it in 2 successive tanks.
The weird thing is, my car seems to be going thru a cycle of running awesome for a few days without the problems, and then it goes shitty for a few days with the problems as bad if not worse than before I fixed everything up.
Arg....
NiGMa
119
Australia
Arg....
got a TSRM?
check your vacuum hoses for leaks.
supramacist
1,501
The Grassy Knole
Forget injector cleaner. Use a qt. of ATF in your next high octane fill up.
It'll burn out more carbon scouring than the injector cleaner and it'll lubricate everything. It's a win, win.
NiGMa
119
Australia
ATF?
supramacist
1,501
The Grassy Knole
Ya ya. Everytime I tell someone about this the thread wigs out.
I'm not lying to you. It won't hurt anything and if you gents try it.
You'll be thanking me. I do it on every auto I own.
It makes the gas something like a 2 cycle oil. Like for a weedeater. Kinda.
It'll make you puff smoke, but that means its working. Run a half a tank and top it off with high octane again mixing the two together and go racing fellas.
It's an old school trick. It's the best injector cleaner/lube you can get.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
It's on old myth that's ineffective and won't die, used by people who don't know any better. Not to mention there are far better ways to clean injectors these days. How about a little science to back up your claim? Even though I already know the answer feel free to explain what's in ATF that you think has such great cleaning abilities. Or what's in ATF at all.
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
ATF? wtf the only thing Iv ever heard of is putting it into your cylinders if a motor has been sitting a hell of a long time and you think the rings might be rusted. If you leave in in for a week it'll seep down through the rings and make the startup alot better.
Shit, if you want to clean your cylinders, do the mexican tune-up.. water :D. Mist water into the intake :)
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
As I suspected. You talk the talk but can't walk the walk.
You've always been one to vomit up misinformation but I've noticed of late it's happening more often than usual. I've let it slide until now. My advice is if you don't know what you're talking about you should STFU. As I've pointed out many times cars have been around 100 years and the SAE has reams of research papers on anything you'd like to know including this subject. Assuming you're not cheap you might want to go to their website and cough up for some.
Mad? Lol. You'll know when I'm mad...
supramacist
1,501
The Grassy Knole
Whatever dude. You were kind of a pompous ass before your title.
I have noticed sinse you recieved it that your head has it's own galaxy.
You have this thing with trying to make anyone that doesn't agree with you exactlly feel small and petty. That's bogus dude.
Vomit is exactlly the word I was thinking when I thought I'd come in here and see what you had coughed up in return.
This site use to be someplace where everyone could come and learn things. There used to be a unity here that is no more. We all used to be brothers that fought for the same cause.
You used to be just one of us. Someone told you that you were someone and you believed it.
You could be albert Einstien man. But it won't matter because your personality is flawed. It must get lonely in your little world.
I mean knowing everything about all of it such as you do. You could be an asset and you choose to be a carcinogen. Someone should just cut you out.
I'm joe blow man. I am every piece of human being that I have seen you belittle in the time that I have used this site.
The ATF bloody well works. You just can't stand for someone to stand up to you and tell you how things are in the real world.
Back when I used to work at the nuclear facility. like anyone gives two spits about you or your past. There is a whole group of nonconformists in here that you can't reach. You may be able to get me banned and that's fine. Because the people I speak to on here know where they can come if they want to just relax and talk car. You're really something else.
You sir are part of the problem, while the nazi's that tell you what to do are landscape.
This guy and his buddies are the ones who decide if you are worthy of being able to use this site or not. And if you don't fit in they just ignore you and don't help you and just tell you how sorry you are when they do type in your direction.
I know I am not the only one to see it. I don't know why I have to risk getting banned to fight for everyone elses rights to be treated with common courtesy. Something that the supposed leaders of this site have waved for their own amusement.
Take it back fellow posters. Without us, these geriatrics have nothing to do or no one to correct. They will just have to pass time some other way while they wait for their next diaper change and the morning shot of metamucil.
I for one..., excrete larger than you.
Status
