bad oil pump, any ideas how to fix?
TheMoneyPit
22
Newburgh, NY
Is it possible to lift the engine just enough to clear the front crossmember? I really don't want to pull the motor again, or drop the crossmember.
TheMoneyPit
22
Newburgh, NY
I had rebuilt the motor 2 years ago, and the brand new pump i put in doesn't make any pressure. so the car has been sitting for 2 years, and i'm finally ready to work on it again. i only need to lift it high enough to take off the pan, maybe 3 or 4 inches i hope.
DaSuprawolf
Im SICK of N/A
Dec 29, 2005
456
ChicagoLand
if only 3 or 4 inches, maybe, you might need to take the valve covers off to clear the fire wall, theres a littel lip there.
Good luck, i hope you re-built runs great!!!
rakkasan
Currahee!!
Fort Campbell, KY
Has the motor made good oil pressure after the rebuild, or has the pressure been low ever since? If it hasn't made good pressure since the rebuild, it could be bad bearing clearances.....
IHI-RHC7
"The Boss"
Oregon
Yep. And if it makes "no" oil pressure, I'd bet on the sending unit being to blame.
No, you can't lift it high enough, drop the member.
Actually, if it makes no pressure, pull the engine.
lagged
1991 1JZ
new rochelle
.... and check the bearing clearances.
TheMoneyPit
22
Newburgh, NY
i only ran it for 3 minutes after the rebuild. i had a mechanic friend come look at it, and he said it's got to be the pump. i pulled the pressure sending unit out of the block, cranked it a few times, and no oil came out of the hole for the sending unit.
rakkasan
Currahee!!
Fort Campbell, KY
your shit is ate up like Hogans goat. "Only" three minutes no oil = fried motor. Time for another rebuild.
