Tests have shown that as little as 0.04% (400 PPM) water in lubricating oil can cut the fatigue life of bearings by as much as 48%.
Moisture is generally referred to as a chemical contaminant when suspended in lubricating oils. Its destructive effects in bearing applications can reach or exceed that of particle contamination, depending on various conditions.
Water may cling to metal surfaces or even form a thin film around solid contaminants such as silica particles. But by far the most damage is done when 'etching' occurs.
Water etching is a common type of corrosion occurring on bearing surfaces and their raceways. This corrosion is caused primarily by the generation of hydrogen sulfide and sulfuric acid from water-induced lubricant degradation. Yes, you read that right water (and anti-freeze) when mixed with oil and heated inside an engine combine to form acid. This eats away the soft surfaces of your bearings in no time.
(Ever notice that a Supra with a BHG for any length of time will have rust in the coolant? - Guess what - the coolant has become acidic by mixing with the exhaust gasses that are getting into the water jacket!)
Remember your bearings are never supposed to "touch" anything but oil. The bearings ride on a very thin layer of oil. Once there is some etching, the oil pressure drops (since the etching has provided the oil with a place to go other than where it is supposed to be) and eventually the bearing touches the rotating surface. After that it's all over.
