Backfire after 6,000RPM
Emilian
161
Farmington Hills, MI
I am currently having some issues with my 1J. After 6,000RPM it starts to backfire like crazy... Anyone has any idea what I could do or change. I'm currently running 20psi on a single turbo set-up.
• 2 coils have a few cracks in them, but they are all wrapped with electrical tape.
• Ignitor is fine.
• Wiring is all good.
• Running a set of NGK Iridium IX - Spark Plugs (BKR6EIX-11) - Gaped to .022
Any suggestions?
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
I just get new coil's once they crack they detra and don't give off the voltage that they once did
remember the coil is copper wound around an iron core
This is jz section. Jz coils crack at the bottom of the plastic down by the plugs.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
Emilian;1841203 said:
Would the NGK 5553 (BKR6ES-11) work?
still a 6 heat range 7 is better they do make them
and you can get an 8 if you get a none Jis plug and go for an Iso it tad shorter but it does work
but an 7 will be good to go plug
