Alright well I have an issue. The guy I bought the car from said the car had low transmission fluid. He was correct the transmission slipped every time at 4000 Rpms.
I put more in and it was fine, so I thought. Now when I go WOT off the line, With the ECT button pushed in, my car hits the rev limiter. I have to let off the gas slightly to let it shift.
I do not know much about the automatic transmissions, on these cars. When I am on the highway it goes into every other gear perfect without the rev limiter. So I wonder if something is wrong with the transition between first and second.
The car does have 139,954 miles on it. I will tell you I have yet to drive a faster stock Supra so far. This thing just goes, even through 110 it will drive perfectly, I am just concerned about the slipping. The fluid I added did help the main problem.
I am curious to see if the ECT button is interfering with something, someone also suggest the TPS, but considering this doesn't happen any other time in any other gears, I doubt that.
I will check to see if without ECT from off the line if it does that, but I don't think it did, it would shift just before 5500 Rpm's. So I wonder if ECT may be screwing somethign up.
Thanks for your input guys, so far I couldn't be happier with the purchase. of the car.
