Auto to manual Swap Q?
Spade
7M or DIE Trying
Nov 26, 2007
Asheville
I have swaped a auto to a manual and the wiring harnis i bought from a neighbor has already been modifed for the neatural safty switch. Will my car run rich when i go to chage gears. Some one told me this. Also will i run into any other problems with my swap? i am going to a turbo trany.
rich? How long does it take you to change gears?
The swap is fairly simple and there are numerous step by step instructions on here. Good luck.
billspreston01
555
North Carolina
I did my swap over 3 years ago. Back then there were threads on this website describing how to do it. Search and thou shalt receive.
On a side note. I don't know if you'll run rich. I didn't switch wiring harnesses though and I don't have a neutral safety switch.
Spade
7M or DIE Trying
Nov 26, 2007
Asheville
tlo86;1004700 said:
so why did you change your wiring harness?
Well im going NA to Turbo And Auto To Manual In one swap. I got a turbo engine with a auto harnis that was modified.
Spade
7M or DIE Trying
Nov 26, 2007
Asheville
Thanks for all the help if is was not for you guys i whould be a Little behind. Im kinda new to supras. Thanks though
