so that would be the difference between the auto and m/t ecu's?
I'm asking because I'm using the motor, harness, and turbo out of an auto, but running it all off a 5spd ecu... with an aftermarket boost gauge that read around only about 5.5psi at full boost... even after shimming the wastegate i'm having to use MORE washers than most people have to use... right now i'm at about 8psi with 5 washers.
