ati super damper + DM pulleys= what belt??
slideways2004
98
Houston
I have driftmotion underdrive pulleys and an ati super damper. What serpentine belt am I supposed to use??
I searched but could not get a definite answer
tsuper92
supra addict
Apr 7, 2005
1,376
mass
the stock belt should fit(stock crank pully with a/c.i have the same set-up
i see the front sump pan,what's the motor going in?
tsuper92
supra addict
Apr 7, 2005
1,376
mass
if your running the ati pulley without a/c pump on the motor,like in your picture.you will need the stock belt,which make's up for the larger diameter pulley.
the stock belt for a/c will work.try the belt that came off the motor.
slideways2004
98
Houston
Motor never came with a belt. I'll see what I can do. If it worked on your motor it should be fine on mine
tissimo
Stock is boring :(
Melbourne, FL
take a rope, feed it through like a belt get that measurement then cut off 1-1.5" inches (for the tensioner). Go to autozone with your measurements and tell them you need a 6 rip xx inch long belt.
