ATF leak
bonus12
Backroads Driver
Jul 15, 2006
143
CA
about every week i have to refill the atf. this gets expensive after a while...
it seems to be leaking out of a black tube. i dont know if i should replace the tube or not. i can't see it that well b/c it is sorta under the engine, so if you know anything about this kind of thing plz help.
any help is totally appreciated.
thanks in advance.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Even the best mechanic can't properly help diagnose over the internet without accurate descriptions, pictures (not entirely necessary, but extremely helpful), and lots of info.
If ATF is leaking out of a tube, then yes. Replace said tube.
DaemoN
205
Wichita, Kansas
www.TeamFE.net
MK3Brent said:
My powersteering leaks too... :(
I had a power steering line crack and puke, so I replaced the every PS line, and it still has a tiny leak! haha, my rack might be shot or one of the pressure lines might not be properly fastened to the rack, still looking into this! It leaks from the driver's side rack boot.
Sorry to continue the hijack! lol.
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Texas Motor Speedway
My power steering fluid was leaking as well from what I believed to be the pressure hose. I replaced that one and guess what, my boots on my rack are so worn that fluid is also squirting from my rack whenever I turn. :aigo:
