You can view the page at http://www.supramania.com/forums/content.php?200-Vacuum-Gauge-Diagnostics
Supracentral Active Member Mar 30, 2005 10,542 10 36 Jan 27, 2012 #1 You can view the page at http://www.supramania.com/forums/content.php?200-Vacuum-Gauge-Diagnostics
Devin LeBlanc Banned Apr 7, 2010 1,830 0 0 32 Las Vegas NV. Jan 30, 2012 #2 10 in hg vacuum can be 100% normal too at idle. If you have 280 deg cams I personally pull 20 in hg on my motor at idle 650 rpm
