ARP head studs
supraken
47
pensacola, FL
Is it actually possible to use them??? As of right now i have the studs in car with the head but i my 12 point 14mm deep well is to thick to fit. does anyone have a brand that fits??? id go look at buying some but nothing is open and i was hoping to gather some info. these studs are becoming more of a pain in the ass then i thought. thanks for any suggestions!
Need a thin wall socket (deep isn't required), I have an old craftsman socket I use for it, but if you buy a cheap socket and grind it down it will work too.
92nsx
2,957
Clearwater, MN
They should work just fine. I used a craftsman deep well, 12 point 9/16, 3/8 drive scocket from Sears for $4 and worked just fine. The only problem had was my casting for the head was off a little so I had to turn down the nuts a little.
But when we did sean's and kelly's sup their arp nuts fit just fine and didnt need any machine work done.
jdub
Feb 10, 2006
10,730
Valley of the Sun
A Craftsman 14mm 3/8" drive will work and will fit the nut better than the 9/16".
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
At the time 9/16" was the only socket I could find that would fit the space. 12 point 9/16" craftsman
jdub
Feb 10, 2006
10,730
Valley of the Sun
That's fine as long as you realize it's the wrong size. For something as important as the head studs, I'm going to get the correct size ;)
