So im installing a new clutch and using ARP flywheel bolts. ARP's instructions state to torque the bolts to 58ft/lbs using their moly lube or 85ft/lbs using 30wt oil.
It seems that many people use loctite instead of lube on the bolts for extra insurance. I would kind of like to use loctite so I know the bolts wont back out. What should I torque to using red loctite? Or just I just use 30wt oil instead? I really don't want these bolts coming out.
For reference, Toyota's spec is 54ft/lbs.
What did you guys torque to?
