Army Navy Fittings conversion.
pyrows666
22
Alviso
So i have access to a bunch of AN fittings.. is there anything recommended and does anyone know off hand of what area's of the engine bay would definatly need a an conversion???
part numbers???
figgie
Twin Cities, Minnesot-ah
there is no conversion.
fittings are only part of it. You need the couplings (threaded male side) to make them work and the bad news, Toyota has always been metric, AN = imperial.
So no direct x-over. Close but requires welding or taping up to imperial size.
oldsking
789
Chapel Hill, NC
Easiest trick to convert the hose to AN fitting size is take the AN fitting size (ex -6an) and put it over 16 ( ex 6/16) and reduce it down ( 3/8 hose) and that will tell you what size hose to run or compare to.
Hope this helps
