Aristo oil dipstick in mkiii question help!!!!!!
JORAMI17
64
FL
Hi all, I am in the process of completing my 2jz-gte swap in my 91 Supra and here I am almost done and realized I don't have an oil dipstick. I figured I would be smart and (before doing my research) got one for an mkIV and.......guess what..........it doesn't fit!:: blonde ::
So my question to you guys is.....any ideas? Should I just make do with what I got? It seems short and no place to attach at the top by the intake.
You can see my build thread here:
http://www.supramania.com/forums/showthread.php?135514-Another-mk3-2jzgte-swap-in-tampa-fl
Dirgle
Conjurer of Boost
Pauma Valley, CA
I did the same thing only to realize that it attaches to the intake manifold support bracket on the USDM MKIV. I was unable to use this bracket due to the BIC motor mount brackets being in the way. So I made an aluminum bracket to mount the original Aristo oil dipstick tube, which no longer had a place to mount due to the change in oil pans. Perhaps you could do something similar with the part you have.
