Need to know if the auto and 5 spd rear ends are the same gear ratio? Thanks Wayne 3rdtimearound
S SPD TRP Formerly 3rdtimearound Apr 12, 2005 526 0 0 64 Katy Texas Oct 8, 2005 #1 Need to know if the auto and 5 spd rear ends are the same gear ratio? Thanks Wayne 3rdtimearound
M mkIIIman089 Supramania Contributor Mar 30, 2005 3,061 0 36 Ohio Oct 8, 2005 #2 http://www.mkiiitech.com/forums/viewtopic.php?t=40 The only ones that appear to be different were in JZ cars. All others depending on model were the same whether it was manual or auto.
Idealsupra Supramania Contributor Mar 31, 2005 2,390 0 0 43 Orlando www.tampabaysupras.com Oct 8, 2005 #3 ratios changed by engine model not trans model... IE NA or turbo not 5spd or Auto
S SPD TRP Formerly 3rdtimearound Apr 12, 2005 526 0 0 64 Katy Texas Oct 9, 2005 #4 Thanks for the info, about to do the autto 5spd swap Wayne 3rdtimearound
Idealsupra Supramania Contributor Mar 31, 2005 2,390 0 0 43 Orlando www.tampabaysupras.com Oct 9, 2005 #5 3rdtimearound said: Thanks for the info, about to do the autto 5spd swap Wayne 3rdtimearound Click to expand... just make sure you get a 5spd turbo driveshaft
