Are Gte knock sensors different than n/a?
bloodasp90
JZwhore of JAPAN
Nov 9, 2007
529
on the river
if i remember right, the knock is just a single wire sensor anyways, so if you got a plug that can go into it, and as long as its wired in right, its fine, i have a single NA knock (rear bank) and a GTE up front, i dont remember if i had to change plugs or not, but i know it works the same.
shaeff
Kurt is FTMFW x2!!!!
11
Around
They're the same. The only ones that won't fit are from a '92 car (or some time in '92) when they switched to the square style knock sensor connectors.
