Apex'i AVCR- How to set boost for each gear?
tissimo
Stock is boring :(
Melbourne, FL
tekdeus;1331827 said:
Reading the manual over and over, I can't find any info on how to set the boost for each gear on my AVCR. I can set start duty, and feedback for each gear, but not actual boost? :1zhelp: Manual: http://www.apexi-usa.com/content/pdf6115.pdf
you cant really set the boost for each gear.
You can take duty away to have it undershoot/overshoot your current boost level by removing/adding duty and then turn off feedback. But you cant set X boost for X gear.
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
you can set boot per gear.. using gear judge..
first get the car setup with gear judge like ij said, for first and 2nd gear i set duty to higest +50 wtih the ct and helped me spool 1000RPM faster on the stock ct... made 406 TQ at 3000 RPM! :)
tissimo
Stock is boring :(
Melbourne, FL
IJ.;1332165 said:
Duty cycle per gear is boost per gear but it's really important to get the gear judge settings right first. (doesn't work well with an auto due to the Converter slip)
:slap:
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Not sure what you mean here. You cranked up the start duty in 1st and 2nd?
I ended up setting the start duty in 1st gear to -17% and it works great! Limits 1st gear to 12psi so it doesn't spin, just lunges forward nicely with a 'lil squeal! :biglaugh: This feature is a must-have for anyone with problems with wheelspin.
grimreaper
2,180
Dallas
^ after your success with the meth it is what i am considering next. Now i have to find one of these gizmos as well (1st and 2nd are useless for me)... I REALLY have to put you on my block list so i stop adding to my parts list... ;)
