Apexi AVC-R
Topher E
Trance Head
Aug 4, 2005
388
Vacaville
does anyone have an installation booklet for one of these? I need o check mine cause the boost controller on it isnt working.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
What do you need to know about the hookup????
I have recently installed it..fairly simple install..and setup...
I seee you are in vacaville???? Is this going in a 1 jz or a 7m powered car??
Topher E
Trance Head
Aug 4, 2005
388
Vacaville
I am in vacaville, CA i need to know where the lines to the WG hook up. I have two hoses just hanging there, well one was routed into nothing by the washer fluid tank. :nono: And this is a 7M application.
Racefiend
OH, YEAAHH!
Apr 6, 2005
106
Bay Area, CA
Give me a call tomorrow Chris, maybe I'll swing by and we can knock that out quick (or diagnose by phone). I'll make sure to plug my cel in tonite as it's been dead the last few days.
Topher E
Trance Head
Aug 4, 2005
388
Vacaville
^^lol i tried calling you today to see what was up and if ya were doing the HG on the MKIII. Oh its supposed to rain tomorrow in the afternoon. What time is good for calling ya?
suprastanger507mgte
Hayward , Ca
Okay here goes:
If you look on the boost controller solenoid :
"COM" port will connect to the waste gate nipple
"NO" port will connect to the charge side/turbo side nipple.
"NC port should be vented to air.
Note:
If you are using a aftermarket waste gate, then the NC port will connect to the wastegate and the NO port vents to air
(you will need to move the barbed nipple to the correct port.)
Then you have the boost sensor itself : the elctrical plug will connect to the harness and then it will connect to a vacumn port from the manifold. YOu can "T" off the vacum going to the stock boost sensor.
Do not use the vacum feeding to the fuel pressure regulator.
Good luck.
I have diagram i f you need it.
Moe.
suprastanger507mgte
Hayward , Ca
Topher E said:
^^ Sweet +1 for all.
Here is a simple diagram: Single setup can be used for the 7m turnbo setup.
I have the PDF for instructions, so let me know upir email so I can forward it to you.
