looking to use the existing q45 tps with my aristo wiring/ecu. any ideas?
empera Authorized Vendor Mar 30, 2005 4,548 0 36 42 Philly. May 4, 2011 #1 looking to use the existing q45 tps with my aristo wiring/ecu. any ideas?
aphxero Member Jul 4, 2006 787 1 16 Seattle, WA May 5, 2011 #2 Q45 green/red 2J VC Q45 black 2J E2 Q45 white 2j VTA1 Does your Q tb have idle switch? If not I usually just jump IDL1 to e2 on the ecu. IDL switch just closes E2 and IDL1 which has +b as it's source. http://www.autoshop101.com/forms/h33.pdf Easy right?
empera Authorized Vendor Mar 30, 2005 4,548 0 36 42 Philly. May 5, 2011 #3 is that the secondary plug? either way i dont have an IAC so it might not be necessary. and yes very easy....thanks a bunch buddy!
empera Authorized Vendor Mar 30, 2005 4,548 0 36 42 Philly. May 23, 2011 #4 can i use a 7mgte TPS with an adapter on the q45 wired up to the 2jz?
super.secret.supra.club Supramania Contributor Mar 22, 2007 1,304 0 0 San Diego, CA Jun 3, 2011 #5 i dont see why not since they both run off the same voltage
Devin LeBlanc Banned Apr 7, 2010 1,830 0 0 34 Las Vegas NV. Jun 3, 2011 #6 yes, We recently did that on a FFIM 2JZ MK4.. Using the DM adaptor and a 7M TPS
