Anyone have a really PORTED stock manifold
bwest
Drafting, not tailgating
May 18, 2005
502
HippieTown, CA
There is a lot of material that can be removed from the stock manifold, especially in the collector area. I almost filled an entire tuna can with what I removed. Just be careful and look for cracks when you do it.
Supra469
495
Maryland
Anyone have pics of their ported stock mani before installation?
Also, how much ported or aggressive can one go on the stocker??
Thanks.
Mr. Y
80 miles away from Kremlin
Do you flowtest manifolds after porting? or you are porting just ports to be approximately equal? Aren't you afraid some cylinders will get different amount of air and will be too lean or rich?
Supra469
495
Maryland
See, that's it! Wow. I didn't know about all that. I have never doen this which is why i'm asking so that I can have it properly done.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
If someone was going to go through the trouble of flow testing their manifold after porting, they'd probably just pony up and buy a better manifold from the start ;).
bwest
May 18, 2005
502
HippieTown, CA
on the exhaust side it really doesn't matter given the restrictions of the stock manifold design. If you were that concerned about cyl-cyl balance, then you need to contact Ron R or Dave@boostwerks and have them fab an equal length runner manifold. Besides, you have that giant restriction called a turbo in the flow path, so unless you are making big power (with an equally large turbine) you will not benefit enough power-wise to justify the cost of a header that can balance the exhaust pulse at the turbine.
The stock manifold is far from being balanced, but if you are running a CT, that small turbine is more of a restriction than the manifold (at the power levels the CT can support).
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
This one was mildly ported. Now breathing for Grimjacks turbo!
