anyone familiar with Lipp boss turbos?
suprafanatic
1,607
Greenwood, IN
just curious if anyone on here is familiar with lipp boss turbos, or has one on there supra... i just ordered one and im looking forward to seeing how it performs. i got the stage 5 57 trim (525hp).. im going from a ct 60-1 so this should be a pretty big step up. also wondering what the internal waste gate is set at on these turbos if anyone knows. thanks
Sep 11, 2007
33
terrace b.c.
i have the boss 60-1 turbo, my wastegate was set at stock level, so not a huge power increase. the rest of my car is pretty much stock though. just waiting for my testpipe to arrive so i can put my 3 exhaust on.
smagnotta
SuprSal
WashPa
suprafanatic;1117729 said:
well im planning on running 15-20psi tuned on my car. so should be a pretty good increase
I have that exact turbo ( stage 5 57 trim (525hp) ), and 20 psi is good for 400 horsepower (on my car -- just came back from the dyno).
Gilsdorf
Street Dragon
Jun 18, 2005
244
Reno, NV
I bought the very first commercially available BOSS 550, it's a stage V DBB 58 trim, it dynoed ~520 at the wheels (lots of other significant power mods).
Matt
simpsons7s
Its pronounced Nu-clear..
Oct 9, 2005
253
Riverside, Ca.
I have one as well, you will like it, very reliable and good spool. Take the actuator rod and check for tension on the wastegate, I had to adjust mine about a full turn tighter to be correct.
zurud
351
Evansville, IN
You guys with the boss turbo, what is the bolt you're using for oil drain flange? I am missing my bolts. Normally on most turbo its m10x1.25. I thought they are using metric fasteners, but when I took the compressor housing off it's sae bolts ( 1/2 " bolts).
Toy-Rific
145
Minnesota
Are you using a Boss turbo? On the Ball Bearing turbo it is a larger bolt than on the thrust bearing turbo.
Greg
Lipp/SS
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
ive got the 67mm DBB. spools fast and pulls hard. just finished with a build and im still working out the kinks so i havent really had much time with it. gonna get tuned and dynoed in a few months so im not sure of what numbers ive reached
-pete
zurud
351
Evansville, IN
Greg
Lipp/SS
Yes I have Boss SS turbo. I think its regular thrust bearing turbo . Its turbonetics chra. ITS compressor Stg 5 to4e 67.
