anyone experience t67 on 1j?
str8_6
master yuepeng
Mar 14, 2007
241
wa
well i think its time to upgrade this tiny t3/t4 as its leaking oil and imo takes too much psi for 350rwhp.
i'm aiming for 450rwhpish 500 on race gas.... i just got my 272 small core crower cams in too..so that should def help.
main question is, has anyone had any experience with t67?...full boost by? dyno sheet?
or is this turbo too big for that kind of power and streetability? i thought of a 60-1 also. thanks.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
wait for tissimo to get on this one, hes got a t67 on his
i dont have mine yet, but within a month or so ill have one
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
i think this turbo is too big for your goals unless later on you want to bump up to around 700hp. a 61mm turbo like a t61 or gt35 will probably better fit your needs maybe even a t60
tissimo
Stock is boring :(
Melbourne, FL
awesome turbo.. With my crower 272s i got 18 psi by liek 4500 rpms and pull hard to the revlimiter.. It was fast! I never got to dyno the car but was 450+.. pulled way harder then my 400whp 2j car i had. Never ran racegas though, i'm sure 20-22 psi would of made 500 without issues
str8_6
master yuepeng
Mar 14, 2007
241
wa
wow thats not bad at all. what injectors were you using? and what a/r was your exhaust?
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
if it pulls all the way to redline then probably a .81 a/r exhuast, usually .68 a/r exhuast sides fall off after 6500 rpms
Spaniard
524
La pearla PR
Standalone? Are your figures on a 1.5JZ too?
tissimo
Stock is boring :(
Melbourne, FL
I had a .70 exhaust.. The cams really helped the top end.. would die off above 6700 before i did the cams..
550 mkiv injectors.. Straight 1j numbers.. but yea I had aem at the time.. High boost wasn't tuned that aggressive though as I had all ready sold the engine, we just wanted to test to see how the cams worked out..
nothing happened to the bottom end.. I actually did some switching around, lol.. Sold the 1j to a buddy.. I had a 2nd 1j swap that i was going to to put into my other 91.. but ended up 2jing it.. so was going to use the 1j back in my blue 91.. a buddy blew his 1j bottom end so sold him my bottom end and decided to try a 1.5j now just need to peice it all together.. lol
Spaniard
524
La pearla PR
Thank you tissimo.
So with a .81 exhaust, this would be a good turbo for me. 700+ I would think? Also, I wonder, how does the T67 compare to the GT40 series?
