Anyone ever made there own intake?
604MKIII
9
Vancouver BC
I was just wondering if anyone has made there own intake, I plan on doing this myself and wanted to know what kind of bends im going to need(I want it behind the pass. headlight motor). Any info appriciated.:1zhelp:
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
do you mean IC piping? most bends are sold in either, 45's, 90's or 180 degee bends?? try the search button and type in IC piping and hit go..
to follow the stock route is about 9ft+- search for cooleze. hes got nice piks
if you mean intake, again try the search button. lots of stuff here..
JesseH
1,153
Englewood, Ohio, United States
I did it with my N/A but didn't run it through the old intake hole, I do still plan on doing this but most likely have to make the hole wider in order to avoid hitting the headlight good luck though
SidewayzSupra
Puyallup
You want the short runner intake for a eclipse. Here is my set up, works sweet(perfect) between my headlight and intercooler pipes. Here it is
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
holy shit that is cool! now if you only had a working headlight too :D
604MKIII
9
Vancouver BC
Man that fits like a glove, but I can weld and love to put my own work into the Supra as much as I can! I think Ill be fine with a 180* thanks for all the feedback.
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
tlo86temp said:
2 socks and a rubberband over the airflow sensor.... :stickpoke
:rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
I remeber when my brother did that, except he used 4 pairs of women stockings, xsmall................. :rofl: :rofl:
SidewayzSupra
Puyallup
My headlights do still work cryoslash, the filter sits in between the headlight and intercooler pipe. I leave the sleepy eye look up for more air intake. But it will go all the way down and back up. It was the short air intake, not sure the year,it also doesn't have to be AEM any other company should be pretty close the same??? I was at my buddies shop with my car up on the lift when I saw it laying on the ground. I scratched my head and asked him if I could have it. Then I through it on my car right then and by chance it worked perfect. Now on a couple notes, I took off the lower plastic so more air feeds into it(car never goes out in rain) I think it would be ok if you left the lower plastic on though. Also worked with stock IC pipes, not sure about aftermarket or if you run your pipiing somewhere else. Thanks
