Anybody used the pre-obd 2 data logger?
deazndude
67
Orlando
In reference to this post
http://www.clublexus.com/forums/per...196-free-toyota-pre-obd-datalogger-found.html
I seem to be having trouble making this thing work properly. I think my settings parameters are wrong. I have a jdm 2jz-gte obd 1 engine in an mk3 shell. It has 550 cc injectors with USDM turbos though. I made a 3 wire plug. After plugging everything in I put it into invert test mode and no 1's popped up. Any help would be much appreciated. I've got it plugged from a com plug, into a midi gender changer adapter, to a com 2 usb converter. I installed the proper driver running on windows 7 32 bit.
mysteryshuttleX
12
Colorado
I checked....
-my settings- in standards for engine.
-Map turbo, kPa-
-48gr per 15 sec-performance of injector
-6-# of injectors
-1-# of injections per 2 revs
left inverse adapter unchecked
Aristo ecu 440s
