Anybody have the MKIII Supra logo?
Turbo Skegget
217
Norrtelje
Thanks alot Jeff! This might work, but I´m still intrested if any body has the logo
in vectorized format such as .eps or .ai.
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
I think it's high enough resolution that you could probably create a vector of it yourself, no?
I don't think I've seen a vectorized version floating around before, though I'm sure someone has one.
Supra469
495
Maryland
Thank you guys.
I was looking for that also.
My co-workers son has an embrodiery machine and I want to create my own design using the stock Supra fonts and logos.
Anyone have the: 2-way Twin turbo 24 Valve also?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Hey, what file format does that embroidery machine use? Do you have some program to convert from vector formats to embroidery formats? I can recreate just about anything in any vector format I want, but damn if I can get it into a DST format so the embroidery shop can use it. :(
51Cards
Back again...
Sep 5, 2007
29
Whitby
www.autosoftsys.com
DST files are a special format used to instruct embroidery machines. They are only really written by software specialized to the purpose as there is a lot of other information you need to enter to produce a file (stitch density, understitching, stitch pattern, etc.) It requires someone fairly knowledgeable in the industry to do anything usable. You can find places on the web that will do it for you. Google "embroidery digitizing" and I think that will get you started.
Turbo Skegget
217
Norrtelje
If anybody is interested I have fine adjusted the logo from 51cards. 51cards can I mail it to you so you can put it on your site for download?
51Cards
Back again...
Sep 5, 2007
29
Whitby
www.autosoftsys.com
Thanks to Turbo Skegget we also have some cleaned up versions of the crude traces I put up. All three links are as follows:
Vector EPS Format (363kb)
MKIII: http://www.autosoftsys.com/supra/Supra_MKIIIeps.zip
Adobe Illustrator AI 7.0 format (traces by Corel Trace)
MKIII: http://www.autosoftsys.com/supra/supramk3vect.zip
MKIV: http://www.autosoftsys.com/supra/supramk4vect.zip
I will leave these hosted as long as possible. (who's kidding who, I have stuff still up there I forgot about 5 years ago ;) )
