Any problem with doing this
supramk3man
414
kentucky
Can i run 440cc injectors with a 57 trim turbo with out any fuel problems. i plan to leave boost stock but, i have some supporting upgrades: cooleeze ic pipes, driftmotion ic, afpr, 3 inch elbow with 3 inch all the way back. the motor is bored .20 has mgh and port head. i would like to put a car together with the stuff i have and not have to starting to do anything extra with wiring. I have a wideband i can put on the car to just keep a eye on things. But again i would like not to have to go to maftpro or any other system. Unless i have to, thanks for the help.
s383mmber1
3,614
Somers New York
I run 440CC with a 57 trim for a little while now at 10 PSI. I would invest in a wideband though.(edit:seems like youve got one)
A few guys on the forums here run 440's in the 375 whp range. I will be running it in addition to methanol injection next week and run the car around the 15 PSI range. Stock 440cc injectors.
s383mmber1
3,614
Somers New York
suprahabsfan;1055951 said:
If you don't have a tuning device/wideband I would strongly suggest leaving fuel cut in place.
QFT.
I run STOCK fuel cut, and i can acheive 10 pounds of boost on my 57 trim. I wouldnt suggest going past that without a wideband. Im using meth injection after 8 pounds for safety.
