Antenna
Montero22
Ormond Beach, FL
:1zhelp:I have got the hole antenna shaved and I'm running a $20 stick on window powered antenna which sucks. Does anyone know of a good antenna?
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
stock works fine..
I bought a working retractible antenna for my 92, looks baller and everyone's amazed such an old car still has a working antenna..
you might have to undo all the hard work it took to shave it..:D
supra90turbo
shaeff is FTMFW!
MA, 01440
You can use the AM antenna which is the upper 3 rows of the defroster grid in the rear window. People have used this with some success, I plan to try it myself as it's an easy job, and the last time I listened to AM was never.
5
Lower rows ;) If your defroster still works more than likely the antenna in the rear window will as well, if not, well...
Kota
105
michigan
i dont know if it works well or not, but theres one on ebay that is made to be mounted to the inside of a body panel for cheap
