Well, went to a different track, that was prepped a lot better.
I let the rear tires(still nitto DR's) down to 12 psi, and got the car to hook decent. I ended up with a 1.95 60ft(a lot better than 2.6) with a 5500 rpm launch and no wheelspin. This resulted in an 11.91 pass.
I was a little bit down on power, because the gasket between the turbo and header had started to leak a little. The next pass it was leaking a lot because the bolts had vibrated loose. So, I think I can still get a little faster.
Anyway, I'm happy as long as I'm improving.
