another road block...
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
well i got my rebuilt head off cylinder head international and got around to measuring it...my digital caliper reads 115.47mm. I know stock is 116 mm.with the the stock size hg being 1.37mm a 2.0mm mhg would be .10 mm over sized right? i guess this is better than undersized?
Would .10mm over screw cam timing?
Also does anyone know how to measure block deck height?
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
lol your right i measured a piece of paper and its .11mm haha...the question is how do i know the block is ok?measure how much th epistons stick out?
gaboonviper85
3,236
Northeast Philly
that I have no idea!! How much metal came off the deck? If it is only a few mm then I doubt its much issue..if it was only decked to clean up then I can't see them takeing off much more then .50 mm which isnt that much and I doubt that would even show on a dyno!
gaboonviper85
3,236
Northeast Philly
I take it your not running a metal head gasket? If it was only rebuilt once and they used a regular head gasket then I doubt the deck was done... They may have ran a stone over it to dress it up but that wouldnt make a difference... Sounds to me like your set and kinda stressing yourself out wanting to be perfect but toyota gives ampel clearance for such things and I am sure your well within tolerance!!! Get that son of a bitch running LOL!
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
yes i am using a mhg and they used a stiock hg when they rebuild it.I mite be stressing out but i do want the damn thing perfect!
the stock pistons are suppose to stick out the block a little when installed, without the gasket.if they stick out further than .012"-.020" then the block is shaved....
ok i'll just order a 2.0mm and be done with it :icon_bigg
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
ummm... i wouldnt put a mhg on without getting the head and block machined and lapped to an RA under 30. ask me how i know?
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
There is a measurement floating around on here somewhere for the block. Measured from the crank sadle to the block surface. I'll see if i can find it.
Edit: its 198.5mm stock
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
thank you!now if i could find anything that big to measure with!
