Another MkIII No start
92ma71
67
Fairbanks, AK
Okay guys, I just picked up an 89 Turbo Five speed Targa for 800. The guy had all kinds of crap not connected so I went through everything cleaning all grounds and making sure everything was connected.
I also reset timing per the TSRM.
The problem-
No fuel, No spark
The EBC will not power on which makes me thing the ECU is fried. I did alot of research on testing the ECU and im pretty good with electricity and Ive been searching all day.
okay so just messed with it for a few hours. The fuel pump will not turn on even with the two wires in the diagnositc connector jumped. Also the only wire getting 12 volts to the ECU is the BATT wire. The IGSW wire is not getting 12 volts either.
The key is loose to the point that I can pull the key out with it in the on position. Is this normal?
Im trying to get this car right to swap the 7m into my MK2.
If anyone can help make a simple way for me to test what I need to test. I would greatly appreciate it. Im in California visiting my dad for a couple weeks and were trying to have some fun working on some supras.
92ma71
67
Fairbanks, AK
Anyone? I feel like im so close to this? Ive done hours of research and Im really not comprehending
Just realized the the CEL does NOT come on at all when I put the key in the on position. Does this automatically mean the ECU is fried?
Also there is a red wire and yellow wire coming from main harness under intake manifold. The end of it is the same 2 wire oval end as the horn wire. It is a male wire plug. Can anyone tell me where this goes?
92ma71
67
Fairbanks, AK
So I got another ECU and still no start. I really need to figure out where this one plug goes from the main harness under the intake manifold. One wire gets power so im sure its used. Anyone in the supra community can help me out?
jetjock
creepy-ass cracka
9,439
I'm corn-fused. If you're good with electricity why not simply signal trace the relevant circuits using the TWED? Or is there something about the diagrams you don't understand? If so ask.
The key coming out means you need a new key...
ifyouaint1sturlast
Banned Scammer - I'm whitemike.
Jun 14, 2011
480
Fort Myers/Cape Coral - Florida
You're missing something.
Power is making it to your ECU - which is how you arrived that your ECU is bad, right?
Perhaps it's the signal that tells the ECU that you've turned the key ;) Personally, I think your issue is C ..
jetjock
creepy-ass cracka
9,439
From what he's written it looks like the ECU isn't getting +B. No MIL, no +12 to the coil packs, no fuel pump when jumped, ect. The absence of +B is likely because the main relay isn't on which in turn is because there's no power at IGSW. If I were him I'd be focusing on that. There must be +12 at IGSW for the ECU to wake itself up and turn the main relay on. BATT is only for keep-alive.
92ma71
67
Fairbanks, AK
Yes I just dont how to diagnose and figure why there is no 12 volts at IGSW. I swapped ECU's and no change. So the IGSW gives 12 volts which then engages the main relay?
92ma71
67
Fairbanks, AK
I am getting 12 Volts to the Coil packs but still no spark.
IBoughtASupra
4,455
Queens, NY
When your key is on, does the check engine light come on? If not, your ECU is not turning on and you need to make sure you are getting voltage to it. Follow the diagram posted above.
Does the fuel pump prime now that you say you have 12V at the coils?
IBoughtASupra
4,455
Queens, NY
You still are not getting your ECU to turn on Have you verified that the ECU is getting a signal to turn on?
Here is a pinout and get to work and let us know what you find. This is an 89+ Grey plug ECU pinout. The yellow plug ECU pinout is different, if you have the yellow plug ECU, use the second pinout.
IBoughtASupra
4,455
Queens, NY
Read the diagram and see what you think would turn it on. The locations are dependent on the year of ECU you have but EACH LABEL does the same thing in each diagram.
ifyouaint1sturlast
Jun 14, 2011
480
Isn't that what I wrote?
"the signal that tells the ECU you've turned the key" and I pointed that I think the ignition switch is the problem ..
My reasoning was that the ECU triggers the EFI relay, and the EFI relay controls everything he's lacking power.. The ECU HAS constant power, but not switched power..
8,900
92ma71;1838376 said:
The problem-
No fuel, No spark
Your answer was already provided, or at least the direction on what to do. But I have a comment for you. I spent a good amount of time at Toyota. A bad ECU is very rare. In fact, in my years there, I saw one. Contrary to what you read on the internet.
92ma71
67
Fairbanks, AK
Gave IGSW power and it fired up. Pretty sure the ignition switch is bad giving the fact I can pull the key out with it in the on position
Smartparts
146
CT
Mine also does this, but the switch is still good.
