Need this graphic with a black back ground and each supra picture the same height.
MDCmotorsports Offical SM Expert: Turbochargers SM Expert Mar 31, 2005 4,194 2 38 44 Indy 500 www.MDCmotorsports.com May 24, 2006 #1 Need this graphic with a black back ground and each supra picture the same height.
87soup F*CK SMOG CHECKS!!! Jan 23, 2006 864 0 0 Sacramento May 24, 2006 #2 MDCmotorsports said: Need this graphic with a black back ground and each supra picture the same height. Click to expand... Do you just want the picture the same with a black BG/ same size?
MDCmotorsports Offical SM Expert: Turbochargers SM Expert Mar 31, 2005 4,194 2 38 44 Indy 500 www.MDCmotorsports.com May 24, 2006 #3 The first picture listed.... I need it with black background. I also need the immage with all the supras the same height.
Yellow 13 Lurker Apr 4, 2006 2,308 0 36 Fairfield, California May 24, 2006 #4 Will this work, I had to change the width dimension a few pixels.
MDCmotorsports Offical SM Expert: Turbochargers SM Expert Mar 31, 2005 4,194 2 38 44 Indy 500 www.MDCmotorsports.com May 24, 2006 #5 THANK YOU SOOOO OMUCH!
GrimJack Administrator Dec 31, 1969 12,377 3 38 57 Richmond, BC, Canada idriders.com May 24, 2006 #6 Damn, beaten by the Yellow 13!
NATAN666 yarrrrr Apr 4, 2005 289 0 0 39 BC user.dccnet.com May 25, 2006 #8 grim's is nicer that other one musta been some mad MS paint work. j/k it's all good
Yellow 13 Lurker Apr 4, 2006 2,308 0 36 Fairfield, California May 25, 2006 #9 Didnt know if he wanted it the same dimensions as the background it was already on. Woulda cropped it but the request was kinda broad. so eh.
NATAN666 yarrrrr Apr 4, 2005 289 0 0 39 BC user.dccnet.com May 25, 2006 #10 well i did one that was smaller in physical size and storage wise (always good for the server) plus, i had to change something/ basic photography: subjects shouldnt point to the outisde of the picture unless to convey a negative mood. Attachments mdc.gif 23.9 KB · Views: 16
