Announcing the ECUMaster EMU PRO!
Zach
ECUMaster USA
Apr 6, 2005
375
TX
Announcing the ECUMaster EMU Pro!
Scheduled for release in the third quarter of 2016, the ECUMaster EMU Pro is the next generation high performance engine management system from ECUMaster!
Pricing information will be announced at a later date.
The EMU Pro features the following capabilities:
Supports up to 8 cylinder engines in sequential operation, and 12 cylinder engines in semi-sequential operation
User definable current control for injector output channels (for low impedance injectors)
Advanced data acquisition system with up to 512 Hz logging per channel and 2 GB internal memory
Built in 3-axis accelerometer
Advanced paddle shift and gear change cut strategies
Support for VANOS, VVTi and other variable cam systems (control for up to 4 cams)
Sophisticated Drive By Wire support for 1 or 2 throttles
Advanced fueling algorithm based on resultant engine volumetric efficiency
Built in dual-channel wideband oxygen sensor control (for Bosch LSU 4.2 or 4.9 sensors)
User-definable output channel assignments
3D tables resolution up to 32x32
Engine protection functions
Free firmware updates
Waterproof housing (IP67 standard)
8 Injector channels (high or low impedance)
8 Ignition channels (up to 15A, smart or passive coils)
16 Auxiliary outputs (6A)
2 H-Bridges (up to 6.4A)
2 CAN BUS Channels (CAN 2.0B)
1 Serial Output
16 Analog inputs
2 EGT Inputs
2 Knock sensor channels
5 Trigger inputs (1 crank, 4 cam, Hall or VR)
4 Wheel speed inputs (hall or VR)
1 Flex Fuel Input
1 Turbo shaft speed input
Dimensions: 160x128x32 mm
