American ge - JDM ge?
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Texas Motor Speedway
Fuzz420 said:
yes you will need your oil pan, and intake manifold.
The jdm ge's are from cressida as they didnt put the ge in supras in japan.The rest is plug n "pray"
That's not true, I just switched the two out like mentioned, mine is working perfect.
-Matt
Neil
Poker of the Smot
Apr 29, 2006
87
In the Supe
Thanks, I had some unreliable sources telling me other wise.. Might have to go knock some teeth out :p
trydrew
Suprafied
Nov 4, 2005
1,038
Earth
It'll all depend on what car the donor heart comes from. When they pull them, it is possible that theyll sell it as a 7mge, not a 7mge from a cressida. So there is a chance youll get a cressida engine. In that case, an oil pan replacement would need to be carried out.
supra90turbo
shaeff is FTMFW!
MA, 01440
7MGE in Japan only came in the Cressida, which is front sump.
Therefore, if any of you got a "JDM" 7MGE that is rear sump, then it's not JDM!
supramacist
1,501
The Grassy Knole
speaking of oil pans...., mine is leaking on my 91 supra. Can I just replace the seal and be good to go, or do I need an entire oil pan and the seals??? thanks.
1TuffSupra
Sho' Nuff
500
Raleigh, North Carolina, United States
yeah man, just replace your gasket. If it is leaking and its not from around the seal then you would probably need a new oil pan. But if it isnt from a seal you should also be able to see a gash in the pan.
With JDM 7mge's they all came from cressida's so yes you do have to change the oil pans out. You dont, however, have to change the intake manifolds. The motors are the exact same from the oil pan up.
Toyota Cressida motor:
Dirgle
Conjurer of Boost
Pauma Valley, CA
BINGO! I didn't think it would have been that hard of a connection for people to make. :eek3dance
