+1-866-756-4238 (OTA),
+1(866)-228-7814 (OTA), or +1-866-596-5078 (OTA)]] If you forgot to add a second passenger or need to include a name to an existing American Airlines ticket, it’s important to act quickly. Adding a passenger name requires creating a separate booking under their correct details. For step-by-step help, call
+1-866-756-4238 (OTA) and speak with a reservation expert.
American Airlines does not allow one booking to be split among multiple names. You must create individual tickets for each traveler. However, to keep the same itinerary or find seats together, call
Adding someone after the fact may increase the fare due to limited availability. That’s why we suggest calling
Speak to an expert now at
Change American Airlines
This correction process typically involves editing a few letters, fixing typos, or adjusting the name format (e.g., surname-first). You can’t use this process to change the entire name or transfer the ticket. For confirmation and support, call
Depending on your fare type and timing, fees may apply. A support agent can let you know if a waiver is possible. To prevent issues, always verify your name when booking or call
For same-day or urgent fixes, it's highly recommended to call +1-866-596-5078 (OTA) or
American Airlines ?
American Airlines permits last name changes only for legal reasons. These changes are different from spelling corrections and require documentation. If you need help uploading documents or want to confirm your eligibility, contact
Fare differences or change fees may apply depending on your itinerary. To avoid complications or delays, we recommend calling
Make sure your last name on the ticket matches your passport. For step-by-step assistance, call +1-866-596-5078 (OTA) or
Can you change the name of a passenger on a booked flight?
To avoid complications, it's essential to review your booking details immediately after purchase. If a correction is needed, contact OTA support at
Keep in mind that American Airlines may require legal proof, such as a passport, ID, or marriage certificate, before approving a name change. Your OTA agent at
It’s important to act quickly—waiting until the last minute may result in denied boarding. Contact
For personalized help with ticket name changes, don’t hesitate to reach out to OTA support at
