Am I missing something?
yhatzee89
Joe Yantz
Aug 31, 2012
979
4
San Antonio, TX
I just got my new harness and some of the plugs don't seem right...
This is the igniter plug
And then this thing... I have no idea what it goes to
And suggestions? Thoughts? Ideas?
scottiedawg66
Bay Area Ca
is that an A70 (supra 1jz) harness? The 2nd plug, the white one, looks like a knock sensor plug to me. They are under the lower intake manifold, and a real pita to get to.
That's not the igniter plug. Possible auto trans.
Looks like the oil level sensor plug on the upper pan.
For sure not a knock sensor plug.
Intake side of the wiring harness. Down below sort of.
1/2jz ignition is sequential. 6 wires in and 6 out for one plug then the other is for power. And the white one is a noise filter. Should have a group with 3 connectors like your igniter.
Turbo Habanero
4,229
Tucson,AZ
Do have a picture of the whole harness played out ?
Reason I ask is it would make it easy for me and others to point out plugs by highlighting them in the photo for you.
TweakTech
45
Summerville, SC
Lyle, That is the park/neutral position switch connector that you're trying to plug into the igniter. Your igniter connectors are down inside the car by the ECU. You will have a 12 pin, a 4 pin, and a light gray 2 pin connector, which will plug into the 3 spots on you igniter bracket. The small white single pin connector is your oil pressure switch for your gauge. This sensor is located on the block behind your A/C compressor.
-Cam, Tweak'd Performance
