Aluminium Crankshaft Pulley
robhojy
swazzy,land
i bought one, and was advised against using it, apperently it messes with the crank harmonics,
a fancy looking peice of crap
get an ATI super Damper or keep the stock pulley
Doward
4,245
Alachua, FL
ATI Super Damper is the only way to go, imho.
And yes, it is a 'Damper' of crankshaft harmonics - a lightweight pulley does nothing to dampen the harmonics of the crank.
Wayne G.
87Turbo 5sp Targa
Apr 19, 2005
213
Gainesville,Ga.
From what I have read here and other forums if you want to reduce rotational weight flywheel and driveshaft would be better ways to go,,
Some have said if you get everything "too" light it takes lots of reving to and clutch slipping to get going. After all my reads I decided to use lightweight flywheel and alu. driveshaft and "stock crank pulley" and not have to worry about possible bearing problems and a touch better driveability.
figgie
Twin Cities, Minnesot-ah
ATI pulley... It is new and rebuildable.
OEM unless brand spanking new from Toyota...... is more than likely not DAMPENING at all now a days. The rubber material is "toast" by now.
