Their is a sort of grinding noise coming from the alternator or belts. The battery has not died so i know the alternator is working. What could be making this noise?
Thanks
Thanks
whowouldfigga;1266572 said:Double check it is the alternator by putting piece of wood or something rigid on it and listen through it on the other end like a stethoscope. I use a hammer with a wooden handle. Mind you don't get your tie caught in the belts and get sucked in. I had one alternator get so hot when it went bad you could fry eggs on it but it was still charging.
Kckazdude;1270785 said:Is it the compressor or the tensioner bearing making the noise?
grimreaper;1271213 said:Spin the tensioner pulley by hand, is it smooth or gritty? Sometimes they will make the noise if you can spin it fast enough too
