Alternator good but not charging
Freshmaker
396
Oconomowoc, Wi
My voltage gauge dropped down to about 9-10 volts yesterday. So I went out and bought a nice new SC300 alternator. (bolts up and fits nicely btw) After the install, I start my car to double check everything, and the problem is still there.
Here is where I am after some frustration: I have battery voltage on each side of the 100A fusible link. I don't have voltage at the pole off the alternator. My question is, can I just run a new wire from the fusible link to the alternator? Does the stock harness have any splices in there?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
the alternator wire from the fusebox? yes, its not apart of 2jz harnesses and we do that anyways. do a load test on your battery to see if it is still good
aphxero
787
Seattle, WA
does the sense 12v have continuity to the battery? And does the ign wire on the alt getting power from charge fuse?
