Was wondering if anyone has had this issue.. recently car has started to run rich under boost. Just a random occurace.. no changes to sfac2..
I swapped the air temp sensor with one from a 2j. The problem was fixed.. so I added fuel back in to the curve (I took some out trying to fix the rich issue).. car ran fine for a couple days and now the rich run issue has returned. So not wanting to try to pull fuel again due to fear of issue fixing itslef as random as it started, don't want to damage motor with lean conditin
So can this be the ecu starting to fail.. I have a map sensor I can also swap of a 2j but I really don't think its the map. Sorry for sloppy post sent from my phone.
And the motor is a 1j with single turbo 264 cams
