Aftermarket turbo, different cooling!!!??
PorterzSupra
703
Hebron CT
Thanks, for the info, just a few more things... The 2 threaded holes on the wastegate, where do they go?? Also the hole in the hot side of the turbo it appears just dump exhaust gas from the manifold to the downpipe, whats the purpose of this hole? I am welding a adaptor flange to my stock turbo elbow and I dont see the point of have the hole there?? Thanks guys I am new to the afermarket turbo world but learnring fast with your help!
siman
Lifetime Ban
Murfreesboro, TN
PorterzSupra said:
Why wouldent the aftermarket companys take advantage of watercooling? I guess it must not be that great... Anyway where do the 2 threaded holes goto on the external wastegate??
Buddy, I am not sure your on the same page as we are here.
The external wastegate does not connect to the turbo in any way. Those TWO ports ( one smaller than the other ) are oil ports.
Judging by your previous posts, it seems you have a T4 without oil jackets right?
Ok, the SMALLER port is the oil FEED ( oil goes in from the block here) and the larger port is the oil RETURN ( oil going back INTO the block).
The reason most companies do not put coolant jackets in the turbo's is that it takes up TOO MUCH space inside the housing...that space is utilized for oil...the turbo's are built to a better level of performance where they can withstand higher temperatures better than the stock turbo's.
And if you think about it, that coolant coming out of our stock turbos is INSANELY hot......and its being fed right back into the system...
I dont know about you, but commen sense says hot coolent no good!
Hope this helps some. If you have any questions please ask! If you do not know how to ask the questions...well ask anyways!
-Jonathan
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
lagged said:
most arent water cooled. just loop the stock turbo water lines.
what about in my situation... where I will be replacing my stock turbo with my lipp boss stg v... will I have to route lines for the water cooled turbo?
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
