aftermarket gauges
karlmk3
336
thornton
where do i need to hook up the aftermarket boost oil and temp gauges pics would really help 1jz cant get factory gauges to work still cant get tach to work. thanks for all the help
A-to-the-J
Panda™ and Pre-89 Gracer™
Feb 19, 2006
1,080
Anaheim/West Covina, CA
For boost, you can T in right behind the intake manifold. There's a vacuum port back there.
You can get a sandwich adapter plate that's tapped for a sensor (for oil press. & temp).
What temp gauge did you get?
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Yup boost has to be post throttle body so your gauge can see vacuum and boost.
I have a prosport sandwich plate, great quality. Most oil pressure senders and oil temp senders are 1/8NPT. May be different for your sender. What brand is everything?
karlmk3
336
thornton
just the cheap autozone ones so i can still monitor the health of the moter im still debating the final gauges when i get some more money
karlmk3
336
thornton
where is a good place to do the oil pressue? and my tach dont work where is a good place to put an aftermarket tach for a temp fix? i want to get the most accurate reading. and why in the hell is my tach not working fuck
