Aftermarket Crank Pulley
TurboWarrior
Canada
I just have a question. Its bugging me don't know why.
The stock Crank Pully is a Harmonic Balancer. Which means its more than just a pulley right? As in its acting as a balancer for the crankshaft?
If thats true whats the deal with these?
^Is this an accident waiting to happen or are they safe?
mkIIIman089
Ohio
The deal is... there is a lot of controversy over those, because they are not dampers like stock one is.
I would never use one, its an "accident" waiting to happen.
The stock isn't balancing anything, its just lessening vibrations.
TurboWarrior
Canada
I see. If the stocker lessens vibrations that means that those vibrations potentially increase engine wear at least right?
silvergsx623
WIPLSH & HWY KNG
Oct 16, 2005
498
Alabama
Correct! save those bearings and use a pully that has a Harmonic Dampener!
jdub
Feb 10, 2006
10,730
Valley of the Sun
Kinda, sorta true...not completely accurate. The stock damper is balanced, you can see the drill marks where that was done to prevent the damper from contributing an oscillation vibration to the harmonics produced by the crank. It's purpose is to dampen (reduce the amplitude) of harmonic vibration...a well balanced crank with matched weight rods/pistons will help even more.
mkIIIman089
Ohio
jdub said:
Kinda, sorta true...not completely accurate. The stock dampner is balanced, you can see the drill marks where that was done to prevent the dampner from contributing an oscillation vibration to the harmonics produced by the crank. It's purpose is to dampen (reduce the amplitude) of harmonic vibration...a well balanced crank with matched weight rods/pistons will help even more.
Well, so it isn't balancing anything, and the pulley itself is balanced. If I'm understanding you correctly. If you want to bring it out on a technicality, I should have said it doesn't act as a counterbalance to the engines internal rotating assembly? You seem to be trying very hard to be like jetjock.
On the well balanced comment, I thought when we talking about harmonics we were talking about much higher frequency vibrations then a non-perfectly balanced rotating assembly would be producing... (Please, correct me if I'm wrong)
jdub
Feb 10, 2006
10,730
Valley of the Sun
This motor is full of "technicalities"...something a lot of folks seem to ignore. Tell you what, if you're interested in what harmonic vibration is and what it does I suggest you read up on it. It's actually torsionial harmonic vibration...the frequency depends on the natural resonance of the crank and the rpm it is turning at. But I digress...I wouldn't want to risk insulting your intelligence.
But I can promise you this, the crank damper had better be balanced to do it's job.
Our motors use 0 balance pullies and flywheels meaning they don't contribute to the overall balance of the motor and in themselves are balanced.
The front pully acts as a shock absorber to catch the twist of the cranshaft during firing pulses, the more hp the bigger the bang the greater the deflection therefore the bigger the damper and thicker the elastic ring needs to be.
