Freshly rebuilt 7mgte, done about 400kms since rebuild. MHG and ARP studs. Still running in engine. Car mostly stock. First problem with engine today.
Drove for about 5 mins, got to operating temperature and then came off throttle to come to a stop, saw engine check light come on and car started making struggling noises as if it was trying to die. When I came to a stop car died straight away. Started it up again, struggled then died. Started up again and quickly took off and parked up (died again). Checked the basics, couldn't see anything wrong. Gave it a couple of minutes then tried starting it, same problem. Had to get it home so started it and took off, first stop it died again. After that it was alright for a few minutes and then just before I got home I tried to see what was making it die.
Coming off med-hard throttle doing 50kmph and engine check light would come on and it would start to want to die, get back on the throttle and it would go away (both the light and the stalling).
Any ideas? When I parked up at home it didn't die.
EDIT:
Here are the error codes:
12
24
31
32
EDIT2:
Code 31 only now. Problem definitely seems to be AFM.
EDIT:
12
24
31
32
EDIT2:
